How to determine if an event case is active
Hi All,
I have an event case and i want to determine if it is being executed.
I tried to set a true/false constant inside the event case but i can only get a value if it is running. Otherwise i get nothing. I want to output this boolean constant so that if the event case is running, it returns true; otherwise it is a false.
This is LABVIEW 8.0.1.
All help is appreciated,
Tai
Message Edited by BestPker on 06-15-2006 03:19 PM
(2,953 Views)
Hi Tai,
if you wire the Timeout- terminal with a constant other than -1, then the Timeout will execute. From this you can pass your False-constant.
Greets, Dave
Message Edited by daveTW on 06-15-2006 09:27 PM
Greets, Dave
(2,943 Views)
Thank you dave , it worked out great.
Tai
(2,932 Views)
