How to delete elements from a cluster?
Hello. I would like to know how to delete elements from a cluster. I got stuck with this problem. There is its own order of each element in a cluster. I tried to initiate an array but it seems like too complicated. In the attached file, I want to obtain only the data from "flow" not "pressure". I try to use array programming but it doesn't work. Would be nice if you help me to fix the file. Thanks
Message 1 of 9
(8,389 Views)
You cannot delete elements from a cluster, they are fixed size at runtime. It seems you want to create an array of all  values where save=true. This can be done with one simple loop.
Message 2 of 9
(8,386 Views)
I'm pretty new with the software. Do you have any suggestions in this case? I would appreciate if you fix my programming in the file. 🙂
Message 3 of 9
(8,384 Views)
Try something like this.
Message 4 of 9
(8,381 Views)
Hi Bombboo,
you consequently don't use autoindexing for loop inputs, do you? I tried to clean up your VI (see attachment), but kept the single steps in separate loops. Christian probably shrinked the BD even more...
Btw. why did you replace an array element by itself (highly Rube-Goldberg)?
Message 5 of 9
(8,377 Views)
Accepted by topic author Bombbooo
Thank you so much. Your solution is the way better than my confusing file. 🙂
Message 6 of 9
(8,371 Views)
What about if I want to store data into the pressure array too? Do I have to create another loop or it can be done in the same loop as the flow loop?
Message 7 of 9
(8,362 Views)
All in the same loop...
Message 8 of 9
(8,360 Views)
Try this, for example. Modify as needed.
Message 9 of 9
(8,348 Views)
