How to deferring waveform
How to change pic.(power_1) to pic.(power_2)?
Message 1 of 8
(3,260 Views)
if you want to do that you can't use a waveform you have to use XY an graph. Only XY Graphs can have plots that have many Y value for the same X value.
Hope this helps
Epictetus
Antoine Chalons
Message 2 of 8
(3,252 Views)
With the XY graph that was suggested, you can see an example here: http://zone.ni.com/devzone/cda/epd/p/id/2207
Message 3 of 8
(3,247 Views)
Thank you for your help, but I use ' the FFT power specturm.vi' to make the waveform ,so I can't get the X and Y value.
I holp to get more help, Thanks again !
Message 4 of 8
(3,217 Views)
Well of course you can get the Y array and then you can easily build the X array base on the To and dt.
Let me know if you need help to do that.
Epictetus
Antoine Chalons
Message 5 of 8
(3,214 Views)
Thanks so much, can you give any examples for it.
Use FFT power specturm.vi to get X(amplitude) and Y(frequency) .
Message 6 of 8
(3,209 Views)
YES I need your help for that
Message 7 of 8
(3,198 Views)
All you need to do to get the X array is to use the Ramp Pattern function. In your case you'd want the Ramp by Delta instance since you have a t0 and a deltaT.
Message 8 of 8
(3,192 Views)
