How to declare a pointer to structure element which is array structures
 LStr, *LStrPtr, **LStrHandle structure is taken from LabView cintools extcode.h
   I used: sprintf(((*(*in_array)->Strings[*count])->str), local_str); to pass local_str string to
LabView array.  It worked fine, but  one programmer adviced me to change code to  be more readable.
Means - to change  (*(*in_array)->Strings[*count]) construction to a pointer. I tried many different
ways to implement this - but in all cases it caused LabView to crash. I understand that this question
is related to C programming not about LabView, but could you point me at a place where I have mistake ?
The most likely incorrect string is " LV_array = &(**((**in_array).Strings[*count])); "
Thanks in advance.
1.  typedef struct {
2.        int32   cnt;            /* number of bytes that follow */
3.        uChar   str[1];         /* cnt bytes */
4.  } LStr, *LStrPtr, **LStrHandle;
5.
6.  typedef struct {
7.        int32 dimSize;
8.        LStrHandle Strings[1];
9.  } LVStringArray;
10.
11. typedef LVStringArray **LVStrArrayHdl;
12.
13  _declspec(dllexport) void avg_hello(int *count, LVStrArrayHdl in_array)
14.      {
15.
16.       unsigned char *local_str="Entering function ma_in()";
17.       (*count) = 0;
18.       LStr* LV_array;
19.
20.       LV_array = &(**((**in_array).Strings[*count])); //Set address to which should point LV_array
21.       subfunc(count, &in_array);                      // Call a function which resizes array (works)
22.       sprintf(LV_array->str, local_str);              //passing string to LabView (not working)
23.
24. }
(4,572 Views)
It looks like you're attempting to return the address of 2 defrerences [ $(**... ], have you got a useful error message from a failed build?
_____________________________
- Cheers, Ed
(4,565 Views)
 by changing so:
LStr *LV_array;
LV_array = &(*((**in_array)->Strings));
 warning C4047: '=' : 'LStr *' differs in levels of indirection from 'LStrHandle *'
(4,557 Views)
Have you got the error message from your original attempt?
The pointers and dereferences look like they should be correct in your original post. Is that the line the error occurs in?
EDIT: Actually, I think you might be missing an * before the LV_array->
Message Edited by yenknip on 10-30-2008 04:31 PM
- Cheers, Ed
(4,549 Views)
sprintf(LV_array->str, local_str);  - compiles without warnings, but I get error while running VI
 sprintf(*LV_array->str, local_str); causes:
 >: warning C4047: 'function' : 'char *' differs in levels of indirection from 'uChar'
Message Edited by ACiDuser on 10-30-2008 11:54 AM
(4,531 Views)
Try this in that way:
Should be OK.
Complete source in attachment.
best regards,
Andrey.
Message Edited by Andrey Dmitriev on 10-30-2008 05:54 PM
(4,528 Views)
Accepted by ACiDuser
thank you Andrey Dmitriev! spasibo!
With your example I understood where I have error in my code:
I tried to assign to pointer an address of string which wasn't yet pre-allocated!
that means simply swapping strings we get final code:
1.  typedef struct {
5.
6.  typedef struct {
7.        int32 dimSize;
9.  } LVStringArray;
10.
12.
14.      {
15.
17.       (*count) = 0;
18.       LStr* LV_array;
19.       subfunc(count, &in_array);                      // Call a function which resizes array (works), First we resize array, and only after that we can assign an address of string to a pointer
20.       LV_array = &(**((**in_array).Strings[*count]));  //Assigning address to which should point LV_array
21.
23.
24. }
(4,521 Views)
