How to create waveform chart for different data type
1. I would like to ask how to create a waveform chart for different data types.
2. Why is that when I set the Sampling Time lower than 0.05 (e.g., 0.01), the Profile Elapsed Time becomes very slow (5 times lower than that for 0.05). But increasing 0.05 to like 0.1 or 1, then the Elapsed Time is normal.
Thank you so much for your help in advance!
Roy
(1,357 Views)
Hi Roy,
did you already have heard that we aren't able to debug/edit images of code using LabVIEW? Why don't you attach your VI?
  1. Which "different datatypes" are you referring to? Can you provide an example (VI) explaining which datatypes you want to show within one chart? (Did you read the LabVIEW help for charts as it explains which datatypes a chart is expecting?)
  2. Maybe because of your settings. Did I already mention we cannot debug your image of code using LabVIEW?
(1,311 Views)
