How to create virtual folder in a project programmatically
Venky,
You beat me by just a minute... !Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 11 of 20
(2,391 Views)
Partha,
i clearly understand what Venky wants to have.
If you take a look into the example, the physical folders are added as virtual folders to the project. This is done by the type "folder". You can add any item you like to the project as "folder" and will only create virtual folders all the time.
Testing is the key!
hope this helps,
Norbert
PS: If you don't want to add a physical folder as a virtual folder, the "path" input to the invoke node has to be "Not a Path".....
Norbert
Expert: Geometry
Message 12 of 20
(2,384 Views)
Norbert B wrote:
Partha,
Testing is the key!
hope this helps,
Norbert
Yes, worked for me!
Ben
Message Edited by Ben on 02-13-2009 08:06 AM
Message 13 of 20
(2,381 Views)
I think, from Ben's picture, it is an empty path.
I tested & Not A Path gave error.
Message 14 of 20
(2,374 Views)
Well, works both for me.
LV 8.6 eng. on english Windows XP.
Norbert
Message Edited by Norbert B on 02-13-2009 08:41 AM
Norbert
Expert: Geometry
Message 15 of 20
(2,359 Views)
HI Norbert,
I ignored the example and fat fingered my way to a solution but I used Targets rather than Children.
What is the differnce between the two approaches since they both seem to achieve the same end?
Curious,
Ben
Message 16 of 20
(2,352 Views)
So ... has this question been answered?
Message 17 of 20
(2,348 Views)
Ben,
Children:
Returns an array of references to all children of the referenced project item. You can use these references with the ProjectItem properties.
Targets:
Returns an array of references to all targets in the current LabVIEW project. You can use these references with the TargetItem properties.
Now to the question:  "What is the difference between a child and a target?"
Mainly, i'd say, it is a terminology-issue. Both are "ProjectItems", but specify a little different.
The mayor difference appears in the logical setup within a project:
A project has Targets like "My Computer" (normally not called "child"). Those are not necessarily direct descendants from "Project", so they can be logically be dedicated to other ProjectItems.
Within any target, you have a collection of children, which can of course contain "Targets" (see attached example). This is the point where both termini begin to diffluence.
As a general rule:
- A target is something you add as "New >> Target and  Devices" to the project.
- A child is anything else (VI, ctl, lvsc, lvlib, xml, txt, rtf, ....)
I am not sure if this definition is 100% NI'ish, but it fits to my experience an, at least in my mind, makes sense 🙂
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 18 of 20
(2,344 Views)
Attached you can find an improved version of the Children_vs_Targets_86.vi. Please note that in an ideal world, i would close all references. Since i only read properties, it doesn't hurt too much not closing the references in the end....
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 19 of 20
(2,342 Views)
Thank you Norbert ,it is working.
Rgds,
Venky
Message 20 of 20
(2,311 Views)
