How to create this function in 2018
Message 1 of 8
(4,066 Views)
That looks like a Feedback node.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 8
(4,045 Views)
What are you trying to do? You should be able to use a shift register to do the same thing.
Tim
GHSP
Message 3 of 8
(4,038 Views)
Showing a picture of a tiny piece of LabVIEW code tells us very little, so we can provide very little help.  If you attached the entire VI, we could (a) explain how the Feedback Node works, and (b) suggest  how you might do the same thing the "old-fashioned way" (that I find much easier to understand) using a Shift Register.
Message 4 of 8
(4,012 Views)
Probably not the question , but, whats the initializer dot doing below the feedback node? Either it should be on the loop or it is the standard initializer terminal displayed as a star under the arrow. I cannot create the combination displayed.
More on feedback nodes:
https://zone.ni.com/reference/en-XX/help/371361R-01/glang/feedback_node/
Certified LabVIEW Architect
Message 5 of 8
(4,005 Views)
If i just drop a feedback node from the pallette it has the initializer below.
/Y
Qestit Systems
Message 6 of 8
(3,994 Views)
/Y
If I drop the feedback node from the palette I can get the intializer that looks like either of these, but not one that looks like in the OP.
I wonder if that was some custom vi?
Message 7 of 8
(3,986 Views)
I know I've seen feedback nodes that looked like that.  It may go back to when they were first introduced.  The feature to move them out to the loop, and some other advancements came after they were first introduced.
Message 8 of 8
(3,977 Views)
