Good morning !
I'm a french student in internship in England and I work on the Starter Kit 2.0 (with DaNI Robot). My company would like to transform the obstacle avoidance feature (thanks to the ultrasonic sensor) in a colored line follower (thanks to the ColorPal from Parallax). Thus I want to program in LabVIEW but I don't really know how to get the necessary ColorPal driver or the VIs to communicate between the sbRIO 9632 and this color sensor. I use the same wire as the ultrasonic sensor to plug the ColorPal.
Thank you in advance for your help.
Kevin
Hi Kevin,
I have taken a look at the documentation for the ColorPal and it seems it is programmed using serial i/o. As you can see below:
What you will need to do is use LabVIEW's VISA and Serial functions found under the instrument i/o palette to communicate with your ColorPal. I recommend downloading the ColorPal documentation from their website and study the syntax of the commands you will need.
Also for reference here is a good place to get started when programming VISA.
Kind Regards,
Hi
I'm looking at doing the same thing.
Did you manage to get it working?
