How to create fixed-point number using LabVIEW VI scripting
The snippest used a specific property subset that isn't normally exposed. It was brown due to the private property. The code you posted in your previous post uses the same property (FXPRepBits)
Tim A.
Message 11 of 39
(2,592 Views)
I will be waiting for theresults. Because it is very essential to me to find a way how to do it.
Message 12 of 39
(2,577 Views)
Right.  Your snippet was brown and mine is blue, yet they're the same property.  Is your brown because it was private in an older version of LabVIEW?
Jim
Message 13 of 39
(2,573 Views)
Did you not look at my earlier posts?
Jim
Message 14 of 39
(2,571 Views)
I don't have that FXDRepBits in Property Node options.
Message 15 of 39
(2,558 Views)
You need to learn about snippets; the images in my post are more than they seem.  If you have LabVIEW 2009 or later, you can drag the picture into your block diagram and the code will magically appear.
Jim
Message 16 of 39
(2,543 Views)
The property we are referring to is the same color in both of ours, jcarmody. I was referring to your post here,
http://forums.ni.com/t5/LabVIEW/Setting-the-fixed-point-type-on-the-to-fixed-point-function/m-p/2499...
I see that you're referencing your snippet in this thread though. I don't know specifically what's happening is my suspicion is that, it shows up as brown on my machine because I have access to it as a private type. Even if I move your blue snippet onto my BD, it will become brown. I tested the same snippet on a test machine that didnt have access to the private types, and it stays blue. I dont know specifically why this happens but its almost like the machines that don't natively have access are inheriting it through the snippet.
In the end we should likely wait for what DFGray proposes as the correct approach to scripting fxp's.
Tim A.
Message 17 of 39
(2,529 Views)
Accepted by chikenene
I have confirmed that these properties should be safe to use. Attached are VIs to set them on both constants and controls. LabVIEW version is 8.0. I wrote them in 2013 and saved for previous, so let me know if you have problems. I do not have 8.0 on my development machine. The properties themselves have been around since about 2004.
Message 18 of 39
(2,523 Views)
This gap in scripting FXP-related properties has been reported as CAR 405418.
Message 19 of 39
(2,507 Views)
I got the snippet succesfuly into my VI. Thank you for that!
But the option FXPRepBits works only for DigitalNumericConstant?
Message 20 of 39
(2,479 Views)
