How to create custom square digital waveform
Hello i'm very new to Labview and i would like to ask for some help.
I'm trying to generate a customizable square digital wavefrom. I know how to create a simple repeating high to low to high etc. signal, but how would i generate a signal like this which doesn't just go from high to low and back? I want to be able to repeat high or low values multiple times.
Ideally i would want a binary sequence as an input which would generate the following signal as seen in the picture. How could i accoplish this?
(1,601 Views)
Accepted by eeeeeeeeeeehelp
You could just build a boolean array and transpose it. Then wire it to the block Boolean Array to Digital Waveform.
(1,551 Views)
just what i needed, thank you
(1,513 Views)
