How to create colorized and animated schematic on front panel
I am creating a monitoring system for an air conditioning system. I would like to show the schematic layout of the system and work from there. My problem comes in displaying it. I would like to have pipes change color, make arrows animate to show flow and have a couple other animated gif's to show movement. What is the best way to go about coloring and animated such pipes. My first idea was to make a transparent png then position color boxes behind the pipes and change their color but this seems like a poor solution and I cannot make a good looking connection where two colors intersect. In addition I would have to then animated the arrows of flow on top of the color boxes so it seems like a poor choice. Hopefully I have explained this well enough, any ideas would be great.
(4,091 Views)
About the pipes.. do you know that every control can be customized?
Right click... advanced... customized.
About animations.. use a picture ring and change its value every few msec.
See Labview examples "using custom controls.vi". It is a very nice one
(4,076 Views)
The simplest thing would probably be to just purchase the DSC add-on and you would get all of those controls.
(4,069 Views)
Thank you for the suggestions. I cannot seem to locate the "using custom controls.vi, where is that located?
(4,032 Views)
Help>Find Examples
Search custom and Using Custom Controls and about 10 other VI's will come up.
Message Edited by elset191 on 06-18-2009 02:09 PM
Tim Elsey
Certified LabVIEW Architect
(4,029 Views)
Excellent, thank you
(4,020 Views)
