How to create and store log file in NI Linux Real Time location using LabVIEW
I am working on sbRIO board.
I want to store log data in internal memory of sbRIO board.
with the LabVIEW programming i am can able to create file in VxWorks location but not able to create file in Ni Linux Real time location of sbRIO board.
is there any additional permission/library required. currently, I have installed only recommended library for sbRIO.
(936 Views)
Your inquiry is very unspecific and unclear.
Can you show a VI what you are trying to do?
Both VxWorks and NI Linux use a similar filesystem that looks on the application level like Unix. While NI did create a c top level symlink to make the whole a little more like Windows (and the previous Pharlap ETS embedded targets) there is no real difference otherwise.
If you refered on the VxWorks target to a path as /c/data/something it would be likely now on the NI Linux system something like /usr/local/data/something. Of course you have to check on your specific target and make sure that the according directory really exists before trying to write a file into it.
Rolf Kalbermatter  My Blog
(904 Views)
Thank you for your attention to this matter.
later on, I have checked the read/write permissions of NI Linux directory - for my device.
I found that, writing permission was not enable for group/public. After Enabling it, I can able to create file.
(886 Views)
