How to create a stop button for a case structure VI
I tried putting a while loop around everything in my case structure but the stop button attached to the while loop didn't stop it. I tried adding it to the end of my flat sequence frames but that still didn't stop it. Every time the stop button is reset and so is the vi inside inside of the case structure. What am I doing wrong.
(4,726 Views)
The use of the Stop control in While Loops, and examples of Case Statements and the Principle of Data Flow are thoroughly covered in the first few chapters of all LabVIEW Tutorials, including those on the first page of this Forum.
Here's a question you might want to consider -- Why do you have a While loop?  Is it to allow you to have differing problems to answer?  Why do you have a choice between addition and multiplication?  When do you want to make this choice, at the beginning of the Program (and stick with it) or every problem?  Is this what you are doing with your code?
(4,682 Views)
I guess I should of explained my project a bit. Using a case structure, a loop, and flat sequence frames I have to create two separate case structures, one that presents an addition problem of two numbers between 0-20 allows the user to answer the problem then displays the answer and shows you in some way if you got it correct. The VI is supposed to reset and present you with a new addition problem repeatedly until you hit a stop button. Another case structure needs to be made for multiplication problems with two numbers between 0-12 and have all the other features of the addition problem. I figured out how to do everything but create the stop button. I've re-read my books chapter on while loops but I still don't know what I'm doing wrong. It seems to me like the while loop doesn't include what is inside of the flat sequence frames.
(4,664 Views)
Accepted by benm92
Turn on Highlight Execution and you will see that the Stop button terminals are read in parallel with everything else in the loop.  So you will have to go through another problem before it will stop.  The solution is to add another sequence frame at the end and put the reading of your stop terminal in there.  This way, the button's value won't be read until the end of the code in the loop.
(4,611 Views)
thankyou
(4,575 Views)
I can't open your code because I've not yet installed LabVIEW 2019, but this sounds like a good opportunity for a state machine. You should only need one loop for everything that you're doing.
(4,566 Views)
