How to create a png image in a folder
I am able to  to write the png image on the existing images(i mean it is over writing the existing), actually i want png image to be created in a folder, i mean to say when i run my vi every time a new png image has to be created in the given folder path i dont want to overwrite it.
Ali
(3,335 Views)
Hi Ali,
so you need to create a new file name instead of using the name of an existing file…
What is your problem with this?
(3,325 Views)
I have attached the example code which i got from community.
In the below zip file i have used example vi.
In this example vi the bar code image am writing it using write png. here when i run my vi i want to be create a new png image, for example if i run code for ten times i need 10 png images to be created in a folder.
please help me.
Thanks in advance.
(3,311 Views)
HI shaik,
I don't see any code writing PNG files…
You need to use a function like this - available in more recent LabVIEW versions…
But by reading it's help you should be able to implement the same algorithm using the FileFolderExists (or ListFolder) function!
(3,263 Views)
