How to create a hall sensor simulator using NI USB-6221
Hello.
I'm trying to create a hall sensor simulator using the NI USB-6221.
The idea is to have three digital outputs that outputs a digital pulse train according to six different steps.
See the table below.
And it's interesting to have this working at e.g. 5000 RPM's (meaning 2 milliseconds between each step).
My question is, is this even possible with the NI USB-6221?
I tried creating a simple state machine, driving the outputs according to a predefined table.  But it became evident that this is much too slow.  The NI USB-6221 uses around 10-15 ms to output a digital value from LabVIEW.
Thanks for any ideas on how to do this.
(4,239 Views)
Hi ojohnsen,
yes, that should be possible.
The 6221 supports two AO, two DO and 8 PFI pins, all capable of outputting waveforms (AO, DO) or timed pulses (PFI)…
(4,230 Views)
Hi GerdW.
Thanks for your answer.  Can you give some hints on how you would go about doing this then?
Since it has only two counters, I cannot set three generated output signals with 120 degree phase shift.
Are you thinking about creating pulse sequences on three outputs, and looping these?
BR,
Øystein.
(4,219 Views)
Accepted by ojohnsen79
Looking at the data sheet.
http://sine.ni.com/ds/app/doc/p/id/ds-10/lang/en
Under Digital I/O you can see that the maximum clock rate of the digital lines on Port 0 is 1MHz.  This means you can go from a high to a low once every 1 micro second.  Your hardware is capable.
The software side of things you need to realize that to change the digital line from a high to a low that quick you will need to be using some kind of timing that doesn't involve Windows.  Windows (and other operating systems) aren't deterministic.  So instead of being in a loop changing from one state to the other, put in the buffer of the DAQ card a series of digital states, and then tell the DAQ hardware to play them at a specified rate.  Then your timing is done by the hardware, not by your software.
Search the example finder for Digital - Continuous Output for an example on how to do this.
(4,182 Views)
Hi Hooovahh.
Thanks for your answer.  I found a solution, and you are right, the solution actually was exactly as you suggest.
First setting up a continous counter task to a certain output pin, and then setting up a second task outputting a buffered pattern using the first counter task as hardware timing.
It's then possible to change the "RPM's" of the simulated hall sensor pattern just by real-time changing the frequency of the hardware timing.
(4,164 Views)
