How to create a FIFO array?
Hi J-Spin,
Many thanks for the helps. I get a good result. Beside this, do you know how to put the FIFO SubVI inside a Table Control.
Message 11 of 14
(3,138 Views)
@GaBrieLLiao wrote:
... do you know how to put the FIFO SubVI inside a Table Control.
That question makes absolutely no sense. Can you clarify what you mean by that?
(A table control is a front panel object (typically indicator) and cannot contain code.)
Message 12 of 14
(3,120 Views)
hey sean
how did you get your thing working
can you explain it ?
i need to add values continuously to a fixed size fifo array
all helps are welcomed
Message 13 of 14
(2,921 Views)
You also need code to remove the oldest element from the buffer, right? (else it won't be "fixed size" :D.
simplest would be to keep a fixed size array in a shift register and keep track of the insert point. Read the oldest value from the insert point before overwriting it with the newest value. There is also the data queue ptbypt tool. What have you tried so far?
Message 14 of 14
(2,905 Views)
