How to create OPCDemo - Items
Hi there.
is there a way to create a number of OPC-Items of the OPCDemo-Server? Browsing the Servers with "DataSocket Select URL.vi" i see a folder "Created Items" under OPCDemo. This folder is always empty. Is there a way to create Items for Testing?
Greetings
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,039 Views)
Hello Chris,
unfortunately the OPCDemo OPC-Server only serves a fixed set of different values/functions. But the user has the possibility to modify e.g. the Sine function which is delievered:
An original SINE item is:
SINE:0.0..8.0:2.0
if you modify the name of the OPC-URL to
SINE:-1.0..1.0:1.0
you can create a new item which delievers a sine from -1 to 1 with a periodicity of 2*1= 2 seconds. The OPCDemo OPC-Server now lists this new item in the group Created Items.
Andreas Würl
NI Germany
(3,039 Views)
Dear Andreas
Thanks for your answer. I will use DSTP - Items for testing instead.
Chris
Best regards
chris
(3,039 Views)
