How to create Crankshaft Hall sensor waveform
Dera Lucither
The problem has been solved, thank you very much, so so so thanks
kin
Message 11 of 14
(1,428 Views)
Accepted by topic author 855
Glad to hear it, we finally got there. If the problem has been solved then please kindly indicate this by pressing the solved button, on the right hand side, on the post that solved it.
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
Message 12 of 14
(1,414 Views)
Dear Lucither
I have another problem, hope you can help me.
The waveform you given me that I can’t made an output to oscilloscope via the PCI 6221 and BNC-2120.
Could you tell me how to make that the waveform can output to oscilloscope via the PCI 6221 and BNC-2120. Please, help me again. Attached block diagram for your reference.
Regards
Kin
Message 13 of 14
(1,365 Views)
What do you mean that you "can't made an output" to the oscilloscope?  I assume you have them connected to the scope from the BNC, but do you have the DAQ assistance set to output on those lines?  Does the program run without error, or do you get an error message?  Please be morespecific and maybe post your actual code on this, thanks,
Message 14 of 14
(1,345 Views)
