Expandable Vis
I would like to create a VI similar to the Build Array where I can have unlimited number of inputs, or make inputs increase in discrete numbers. I was told by the NI technical support that I should look into polymorphic VIs and VI scripting. I am pretty sure that polymorphic VIs is not what I am looking for. Scripting seemed a little too complex. I was wondering if someone could tell me a bit more before I spend hours with VI scripting and arrive at nothing.
I came across this post with a similar question http://forums.ni.com/ni/board/message?board.id=170&message.id=298298&query.id=3627080#M298298 that is over 15 months old. Has anything changed since then?
Is it even possible to create VIs that can be dragged to be long and have unlimited number of inputs? Or should I just go about another way to implement what I want.
Warm regards,
Bharath Bhushan Lohray,
Texas Tech University.
Graduate Student, Electrical Engineering.
Message 1 of 10
(6,546 Views)
I don't think anything has changed since that thread was posted.
What kind of inputs are you looking to add?  Is there any reason you can't do it by way of arrays?
Message 2 of 10
(6,529 Views)
Express VIs yes.
As posted in that thrad you will need th toolkit unless you already have it as part of the suite.
i read thru the instructions and you invoke a function that stiches it together and implements the expansion based on your selections.
I think there is probably a limit in the sense that you can only expand down as many inputs as you have coded. So if you code it to acept 12 and you need 13,...
Ben
Message 3 of 10
(6,523 Views)
The above was to pay a long over due request from Bill.
Ben
Message 4 of 10
(6,518 Views)
Could you create an Express VI to do what you want?
( Beat to the punch again 😞 )
Message Edited by Phillip Brooks on 05-24-2010 03:34 PM
Message 5 of 10
(6,514 Views)
@Ravens Fan :I could always use arrays, but I just thought that this would look good. My project involves in creating a "toolbox" - a set of VIs that can be used for application building around a TI DSP platform. I am trying to add an opCode and three operands (UINT16 enumerated data Types) and send it to the DSP as instructions on what to do with data that it is receiving from the ADC.
I don't think an Express VI would work for me either. I think I'll just go with using arrays.
 Thanks for the help 🙂
Message Edited by Lord Loh. on 05-24-2010 02:45 PM
Message 6 of 10
(6,498 Views)
A 2D array is the way to go.  Column 0 for the opcode, columns 1,2,3 for the operands.  One row for each opcode.  Number of rows only limited by size of memory.
Or you could get elegant and use an array of clusters.  The cluster would have 4 elements, one opcode and 3 operands.  Using clusters woud allow better labeling of your elements.  An array of clusters again would only be limited in size by size of memory.
Message Edited by tbob on 05-24-2010 01:07 PM
- tbob
Inventor of the WORM Global
Message 7 of 10
(6,483 Views)
Thanks tbob, that sounds nice. But my final output must be a 16bit word - containing the opcode and operands. I might have to do some shifts and adds to get the desired opcode - operands combination. I'll give that a try and post back if I have good results.
Message 8 of 10
(6,476 Views)
16 bits to contain the opcode and all operands?  Is it 4 bits per field?  You would have to shift the opcode by 4 bits to the left and add oerand 1 to it, then shift the result by 4 bits and add operand 2, then shift the results by 4 bits and add operand 3.  (make sure none of your operands is greater than 15)  Now you have a 16-bit code.  In this case, use a 1D array of U16.  Do your shifts and adds, then stick the result into the array.  You could write a subvi to do the shift and add stuff, and another subvi to reverse the process to recover the opcode and operands.
- tbob
Message 9 of 10
(6,467 Views)
That is what I was planing to do. I am yet to decide what kind of opcodes and operands I want. I have the freedom to allot the bits to the opcodes and operands as I have to programme the DSP to interpret those opcodes. I have about 16 operation in mind at the moment. So I may just allot 5 bits for opcode to expand. The operands shall be input and output buffers of ADCs and DACs or some intermediate storage buffers.
Since everything is fixed, I can have enumerated data typed for all of this and as long as the users of the toolbox uses these enumerated datatypes, they will not mess up the instructions sent to the DSP.
Message 10 of 10
(6,459 Views)
