How to correctly temporarily disable all channels except one in multichannel PID control loop?
Hi All
Help me please resolve the one problem. How to correctly temporarily disable/enable all channels except one in multichannel PID control loop?
Thanks in advance,
Oleg
(3,343 Views)
Accepted by OlegUA
Hi Oleg,
the "Auto?" input of the AdvancedPID is an array - as are sp and pv inputs.
So what's the problem in dis-/enabling just one control loop (aka input) instead of all?
(3,302 Views)
Hi Greg
Could you provide me some example? I would appreciate if you could take any existing example (may be Multi Channel PID.vi from LabView examples folder) and show me which values I should provide to the manual inputs. I've tried to play with it but unsuccessfully. 😞
Thanks in advance,
Oleg
(3,274 Views)
Hi Oleg,
who is "Greg"?
You should provide the values you want to set at manual control. If you want bumpless switching you should provide the last value from automatic control…
Whenever you "try" something you should attach your VI. We will provide hints and comments for improvements…
(3,249 Views)
I'm sorry, Gerd. I hope you excuse me for this mistake.
I've sorted out with your idea a more tight. Currently I've decided to use it (see attached picture) for freezing current state.
Thanks you for help.
Oleg
(3,232 Views)
