How to convert time from mili seconds to micro seconds
I have to interface an instrument using RS422 serial port. While I used VISA Config Serial Port to configure the Port (as attached), I want to input the "time out value" of Property Node (arg 1) in micro seconds rather than mili seconds.
Kindly help me to resolve the issue.
(3,374 Views)
Ben
(3,358 Views)
Well, the smart-alec answer is, "just scale by 1000".  But what I suspect you want is to specify a timeout with smaller-than-miillisec resolution such as 200 microsec.
Sorry to say, that won't be possible.  The API for VISA sets the rules here and it requires an integer # of millisec.  That simply reflects the reality of any regular OS, where it would be disingenuous to make an API that implied that it could reliably *honor* sub-millisec timing intervals.
-Kevin P
P.S.  Oops, second time this morning I started a reply, got interrupted for a few minutes, came back to finish and then saw that someone got there first.  Only this time, it looks like I inadvertantly called Ben a smart-alec.  Which I didn't mean to do, but which he also might not argue against anyway.
(3,349 Views)
-Kevin P
True.
The only alternative would be to cod it up explicitly check the number of bytes at the port and only reading when the right number are there. It would also have to be run on a RT target were sub-millisecond timing of loops can be used.
Ben
(3,343 Views)
@Ben wrote:
Ben
Umm ... you don't like the regular Divide function?
(3,317 Views)
@paul_cardinale wrote:
@Ben wrote:
Ben
I do but I thought I would do something different.
Spoiler
"If you were supposed to divide with the compound arithmetic, you wouldn't be able to invert an input."
Ben
(3,315 Views)
