11-17-2010 08:52 PM
Pls, i want set my simulation time in hours not in seconds while configuring simulation parameters. How do this?
11-17-2010 09:28 PM
Please clearly explain what you want to do and where you want to apply?....
11-18-2010 01:39 AM
I am simulating a hydraulic system and the simulation time has to be in hours for me to see the response clearly. In the simulation parameter the final time is in seconds i want to use hours, how do i change it to hours? Thanks
11-18-2010 02:19 AM
Its possible depending on the architecture you use... Can you post the VI that you made for simulation....
11-18-2010 03:00 AM
Is there any need to post the VI, pls, tell me what to do. Thanks
11-18-2010 03:11 AM - edited 11-18-2010 03:13 AM
Ya it will let us to give a clear solution that you need.... Before posting it save it in LV 8.6 and post...
11-18-2010 07:30 AM
Pls, tell me what to do, the problem is to have simulation time axis to be in hours not in seconds as it is in the simulation parameters, i think this has nothing to do with codes. thanks
11-18-2010 08:01 AM
Without your code it is very hard to understand enough of your problem to help you. We need at least your graph/chart with your data. So if your project is some top secret weapon program, or something else very hush hush (which I find hard to believe). Do at least this. Then you have run your program, and have data in your graph/chart. Stop the program, and copy your graph/chart to a new VI. Then select make current values default. Save the VI, and zip it and post it
11-18-2010 11:44 AM
x3600 ![]()
