How to convert simulation time in seconds(s) to hours(h) ?
Pls, i want set my simulation time in hours not in seconds while configuring simulation parameters. How do this?
Message 1 of 9
(3,671 Views)
Please clearly explain what you want to do and where you want to apply?....
Smiley Wink
Message 2 of 9
(3,666 Views)
I am simulating a hydraulic system and the simulation time has to be in hours for me to see the response clearly. In the simulation parameter the final time is in seconds i want to use hours, how do i change it to hours? Thanks
Message 3 of 9
(3,646 Views)
Its possible depending on the architecture you use... Can you post the VI that you made for simulation....
Smiley Wink
Message 4 of 9
(3,639 Views)
Is there any  need to post the VI, pls, tell me what to do. Thanks
Message 5 of 9
(3,632 Views)
Ya it will let us to give a clear solution that you need.... Before posting it save it in LV 8.6 and post...
Smiley Wink
Message 6 of 9
(3,628 Views)
Pls, tell me what to do, the problem is to have simulation time axis to be in hours not in seconds as it is in the simulation parameters, i think this has nothing to do with codes. thanks
Message 7 of 9
(3,610 Views)
Without your code it is very hard to understand enough of your problem to help you. We need at least your graph/chart with your data. So if your project is some top secret weapon program, or something else very hush hush (which I find hard to believe). Do at least this. Then you have run your program, and have data in your graph/chart. Stop the program, and copy your graph/chart to a new VI. Then select make current values default. Save the VI, and zip it and post it
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 8 of 9
(3,604 Views)
x3600  Smiley Wink
Message 9 of 9
(3,583 Views)
