How to convert numbers to string with optimal number of digits?
Hi.
I am trying to do something that seems quite simply, and I am surprised at how much trouble I am having with this.  I am pretty sure that there is a way to get LabVIEW to do this.
I have an array of numbers (double), and I am using the "Array To Spreadsheet String" function to generate a string that I can write to a file.
The problem I am having is that I want to string to omit unnecessary trailing zeros after the decimal point, but I don't want to limit the precision of numbers that do require it.
For example, if my data is this:
0.02
0.4476
-0.0244570001
I would like for the string that I get to be exactly like what I wrote above.  However, depeding on the format string I use, this is what I get:
format string: %.10f
0.0200000000
0.4476000000
-0.0244570001
<OR>
format string: %f  (this seems to default to 6 digits)
0.020000
0.447600
-0.024457
<OR>
format string: %.4f
0.0200
0.4476
-0.0244 <= all trailing digits for this number have been lost!!
Does someone know what the format string should be to get the string I want (which is this:)
0.02
0.4476
-0.0244570001
Thanks in advance,
Alejandro
(3,761 Views)
Accepted by AlejandroZepeda
Hello Alejandro:
Try %#f
(3,754 Views)
AlejandroZepeda wrote:
Hi.
0.02
0.4476
-0.0244570001
0.0200000000
0.4476000000
-0.0244570001
0.02
0.4476
-0.0244570001
Thanks in advance,
Alejandro
Hi Alejandro,
remember that if  you used a %20f formatter you most likely would see a digit appearing in the .4476 value. Your computer is binary, but your display is decimal, there allways will be rounding errors.
Ton
My LabVIEW Ideas
(3,735 Views)
Hello.
Thanks for your responses.
I tried using %#f, but I got the same result as %f.
Then I tried %#.10f, and that worked exactly as I wanted it to.
Thanks a lot for the tip, DonPogi!
Alejandro
(3,700 Views)
