How to convert data file to audio file in Labview
@austin2017 wrote:
Thank you for ur answer. Actually my qestion is convert a txt file( i convert signal which showing in labview graph to txt file )which include numbers convert to sound file or just signal convert to audio file in labview.  Is that possible?
thank yiu
Well... you're the one who encoded it.  I suppose it's up to you to decode it now.  If all you did was convert the raw values into human-readable text, there's no reason you can't reverse the process.  It should be as simple as reading all the values into a byte array and writing it to a file.  Read up on what a wave file header is if you want audio players to know what to do with it.
Bill
CLD
(Mid-Level minion.)
Message 11 of 19
(2,719 Views)
yes. I checked the Sound palette that was mentioned earlier. all the example are read sound file and write sound file.  I tried to read txt file write to sound file, and  then I tried directly read the input signal and write to sound file. but both failed, the program can not run.
Message 12 of 19
(2,713 Views)
So you've got step 1 and step 3 of what I wrote done.
Sounds like you forgot to do step 2.
Message 13 of 19
(2,711 Views)
I have waveform . Sorry i did not mentioned that
Message 14 of 19
(2,709 Views)
Then send the waveform to the VI I told you about.
If you are still having problems, we can't help without seeing your code.  Attach a VI.
Message 15 of 19
(2,706 Views)
sorry. I am a beginner . I attached labview file.  the input is a signal from data acquisition. I want to write it to sound file.
Message 16 of 19
(2,701 Views)
the waveform lokk like the attached picture
Message 17 of 19
(2,697 Views)
Is there a reason you are saving the data as an excel file?  It would be a lot easier if you just saved it directly, without making any kind of intermediate file.  According to your waveform though, you may have clipping, since it seems you will have numbers outside the range of +/- 1.0.
Bill
CLD
(Mid-Level minion.)
Message 18 of 19
(2,692 Views)
When I open your VI, I see a broken run arrow.  So to figure out what is wrong, I click on it.  It gives me a list of all the errors.  Then I read it and fix the problems.
Did you do that?
I see one error about the Sound Write .VI missing a required input.
If you open context help and hover over that VI, it will show you which inputs are required.  (The terminal is shown in bold.)  You can open detailed help and learn even more about that function, VI.  In this case, your Sound refnum needs to be wired.
Message 19 of 19
(2,687 Views)
