How to control string by program in multicolumn listbox (color, justify, style, size).
It necessary because the dimension of the multicolumn listbox change when the program running and all cells must have the same apearance
Thank you very much beforehand for your answer.
Warmly,
Alain Carbonnel
(2,854 Views)
Please elaborate on your question.
(2,854 Views)
I don't think it is currently possible to do this programmatically. You loose the ability to control the text properties of a string programmatically when you put it in any kind of array.
(2,854 Views)
