How to control a second monitor with labview???
I want to control an SLM(spatial ligth modulator) with labview. This SLM is like an second monitor for my PC. Imput signal of SLM is XGA. The SLM model is Hamamatsu x8267( http://sales.hamamatsu.com/assets/pdf/catsandguides/ppm.pdf ). If someone had the same problem or someone knows haw can it work this in LABVIEW it will be good.
Thanks.
P.S.: I'm new in LABVIEW processing, so I don't much functions or how is work it. I'm wainting for your answer.
Message 1 of 16
(8,509 Views)
If i understand, this is an output device on vga port, and It is utilize to
see images from a file, generated by a digital micrioscope?
Message 2 of 16
(8,499 Views)
Yes, is an kind of out put port, but not for an microscope. For my PC. This SLM must work like an DOE(diffractive optical element), the only diference is that the SLM is an dinamic DOE. Changing the image that you send to SLM, you change the effect of DOE under laser beam, but this is other story. My problem can be reduced to: sending images to an second monitor and that's all. Can you help me? Doen't hesitate to ask me other questions. Thanks.
Message 3 of 16
(8,497 Views)
I cannot go further, but it is more complex
because you don t want to get frame aroud the picture you are sending,
you need to adress directly the second vga driver, etc.....
Message 4 of 16
(8,493 Views)
hmmmm
I don't know exactly how much complex is...anyway maybe there are other guy who can help me.
Thanks for your interes.
Message 5 of 16
(8,485 Views)
If it is an extra monitor (can you see it in your computer setup as an monitor)
You can use the attachement to check the bounds of that moniter, by positioning your VIs in those bounds it will be shown on the SLM.
Ton
Message Edited by TonP on 07-05-2007 01:29 PM
My LabVIEW Ideas
Message 6 of 16
(8,464 Views)
first think: I could not open the attachement because your LabVIEW version is an new one. Then, the second monitor is positioned an left=1025 top=0.
The problem is when I write an image, I write this in LabVIEW windows. You told to put VI in second monitor. I don't know if it's ok., because in the second I want just that image and no other windows.
If you have a solution, it will be good. Thanks.
Message 7 of 16
(8,449 Views)
That's good news (the second monitor thing).
You can move front-panels of VI around with two VI.FrontPanelWindows properties:
  1. PanelBounds, which will set the bounds in such a way that the inside of the window is in th right position, writing this property allow you set it in front of the taskbar
  2. WindowBounds, which will set the bounds of a window (including scrollbars, menus and title bars)
So you need the Panelbounds property, remember that the front panel must be open before setting the bounds (use the OpenFrontPanel method with the state hidden, position the panel and then OpenFrontPanel with state default):
To move the image inside the Panel around look here
Ton
Message Edited by TonP on 07-05-2007 05:17 PM
My LabVIEW Ideas
Message 8 of 16
(8,433 Views)
I have some questions, but maybe is better to discuss via mail. gcojoc@unicz.it is mai e-mail adress.
Message 9 of 16
(8,423 Views)
No!
The discussions are public so that everyone can learn from this!
If you have questions:
  1. Read the LabVIEW manuals
  2. Read a book on LabVIEW (I recommend 'LabVIEW for everyone')
  3. Search the web (Google is your friend
  4. Search NI.com
  5. Search forums.ni.com
  6. Ask here
We're here to help!
You can also try searching this site and google for LabVIEW tutorials. Here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
Ton
My LabVIEW Ideas
Message 10 of 16
(8,421 Views)
