How to control Latronix UDS2100 Ethernet to RS485 using LabView
Hi LabView Gurus,
I have purchased this Ethernet to RS485 device to replace the USB -RS485 converters to have a more flexibility in terms of distance from the controller such as host computer/server. I can't detect the device from the MAX explorer, but the 3rd party software which comes with the device is properly working. I can configure the device in MAX in the web tab. but can't detect on the TCP/IP TAB. CAn somebody help me on this issue?  I'm using labview 2015
Mario
(2,891 Views)
@MarioTalon wrote:
Hi LabView Gurus,
Mario
Why do you expect it to be detected in MAX ?
It's not an instrument.
It's an adapter.
More important is whether Windows sees the adapter correctly or not.
The device is capable of being used in Serial Tunnel mode or Direct TCP/IP or Redirector Configuration mode.  Which mode are you using?
(2,856 Views)
Thanks NYC for the info. Im new to this Ethernet on LabView. Im using Direct TCP/IP mode.
(2,842 Views)
