How to continue loop T/F loop until it is false
Need Help!
I want to compare 2 numbers (Lo and Hi).
If Hi>Lo - Case False: move to next stage
If Lo>Hi - Case True: Post the error messege and ask the user re-enter until it's correct (case False)
Message 1 of 8
(4,529 Views)
Where is the rest of the code? At a minimum you need a loop. Or, do you not have this?
Message 2 of 8
(4,527 Views)
For a while loop right click on the loop terminal and slelect "Continue if True".
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 8
(4,520 Views)
I have a while loop but I need a condition for user to re-enter prior checking T/F again because right now the loop keep running even I hit ABORT button.
Message 4 of 8
(4,505 Views)
Accepted by topic author CP_AT
Can you post your code? It would make it much easier to see what the problem is. In the meantime I attached an example of some code that does basically the same thing you want to do.
Mark Yedinak
LabVIEW Champion
Message 5 of 8
(4,503 Views)
Here is my example
Message 6 of 8
(4,490 Views)
Take a look at the example that I posted. The problem you are having with your code is that you are not allowing the user to get back to the front panel. You have nothing in your code that waits until the values have changed therefore your are putting up the dialog immediately after they press the OK button. The dialog box is being raised so fast that you can't get any other action in such as changing the values of teh controls.
Mark Yedinak
LabVIEW Champion
Message 7 of 8
(4,482 Views)
Message 8 of 8
(4,457 Views)
