How to connect labview program in my computer to an oscilloscope
ramialsaiad wrote:
I have cDAQ-9172 here is a picture : https://www.google.se/search?q=c+series+modules+ni+instruments&source=lnms&tbm=isch&sa=X&ved=0ahUKEw...:
Does that help in producing a signal of 1MHz?
That is a sales picture.  The cDAQ-9172 is a cDAQ chassis.  What modules do you have in it?  Anyways, it will not help because there are not any C-Series modules that can produce your 1MHz sine wave.
Message 21 of 26
(1,392 Views)
@ramialsaiad wrote:
@crossrulz wrote:
@ramialsaiad wrote:
I have something called "national instruments hi speed usb carrier" http://sine.ni.com/nips/cds/view/p/lang/sv/nid/204178 and another thing called "national instruments ni cdaq 9172" similar to this http://www.ni.com/sv-se/support/model.cdaq-9174.html
Can I use them to generate 1 MHz instead of the things you mentioned above?
Both of those are just chassis.  They need a module in order to do anything.  And I am not seeing any C Series modules that can output a signal above 51.2kHz (Niquist states the highest bandwidth signal you can output is ~25kHz).  So that will not work for you.
Hi
Thanks you all
That link only shows some NI products. I repeat, the cDAQ-9172 is ONLY a chassis! Do you have a module inserted into it, or not?
Edit: please read a bit this page: http://www.ni.com/compactdaq/whatis/
It explains what is "chassis" and what is "module".
Message 22 of 26
(1,391 Views)
"there are not any C-Series modules that can produce your 1MHz sine wave" this is the final conclusion of my question's answer.
Now I know that I have to use a real generator to generate my 1MHz sine wave
Thank you very much
Message 23 of 26
(1,385 Views)
@Blokk wrote:
Hi
Thanks you all
Mr crossrulz's answer was the final conclusion and he said that there is no c series can produce 1MHz sin sigal..
Now it is clear for me
Thank you very much
Message 24 of 26
(1,383 Views)
Hi
I have a device called ni9263 http://www.ni.com/sv-se/support/model.ni-9263.html , I can not use it do generate the 1 MHz frequency which I mentioned yesterday !! I just want to be sure now about that
thank you
Message 25 of 26
(1,352 Views)
I'm sorry, but do you know how to read specifications?  The product clearly states it can go up to 100kS/s/channel.  Is 100kHz faster than 1MHz?  NO!!!
Message 26 of 26
(1,341 Views)
