How to conditionally add elements to an array?
Hello Everyone,
I'm trying to use an array to store the time of an event like pressing a button. So "if" the button was pressed then store that time in an array, "else" the button was not pressed then continue. I can't seem to figure out how to do this. Below is some code I made that has the idea of what I want to do but not completely. "If" the button is pressed it displays the output of the time in a numeric indicator and "else" it just keeps displaying the previous time. I saw this post http://forums.ni.com/t5/LabVIEW/Conditionally-add-value-to-array/m-p/1974835/highlight/true#M653360 but I can't open the vi because it's a newer version and I don't understand what is happening. Your help is appreciated.
Max
(7,080 Views)
First of all, you don't have any arrays on your diagram. If you want to append to an array, use a "built array" node inside the case, and keep the array in the shift regsiter.
(You should also initialize your shift register. Also, you have a mismatch in datatypes. your indicator should probably be blue. You should also use a latch action boolean, not a switch.)
(7,070 Views)
Thank you for your help. The latch when pressed action is much better, now it doesn't gather up a bunch of times when the button is pressed. I'm close to having it, I think my loops are wrong or my array is wrong? It doesn't look like the I32 array in this tutorial: http://stackoverflow.com/questions/9863450/how-to-store-values-in-array-inside-loop except they are using a for loop, how would I implement a while loop?
(7,054 Views)
@mbigras wrote:
...I'm close to having it, I think my loops are wrong or my array is wrong? It doesn't look like the I32 array in this tutorial: http://stackoverflow.com/questions/9863450/how-to-store-values-in-array-inside-loop except they are using a for loop, how would I implement a while loop?
I don't see where you think what you have is wrong.  What part of your solution does not meet your requirements?
(7,049 Views)
Because your loop counter is still incrementing even when you don't push the button. Also, your indicator is outside the loop so it won't update until you press stop.
(7,048 Views)
