How to compile waveform file
I need to generate a waveform out of data generated by MatLab. How to convert a ascii data file to a
LabView waveform file?
(2,765 Views)
Hi
A LV Waveform consists of a starttime (x0), a time-difference between eacht datapoint (dt) and the data (X).
So if you want to writa a waveform-file, you have to create a waveform using this information. So extract these data from your text file, convert it (if necessary) and create the waveform.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,756 Views)
Assuming that your file contains tab separated ascii data, the attached vi illustrate becktho comments and shows how to create and display a waveform with LabVIEW.
Chilly Charly    (aka CC)
(2,753 Views)
