How to compare values, wait if it different and adjust
Hello!
There is a range of X values that is equivalent for certain Y levels, for example from 500 to 1000 (X) equals 5 (Y), from 1001 to 1500 equals 4, 1501 to 2000 equals 3, 2001 to 2500 equals 2, 2501 to 3000 equals 1. If my X at 1400, level 4, changes to 1600. How do I get LabView to wait 10 seconds to see if X returns to the range 1001 to 1500, if it doens't go back to this range, change level Y to 3, and keep checking, always plotting that Y value.
Thanks!
Message 1 of 12
(4,304 Views)
Please attach your VI. All we can tell from the picture is the presence of many coercion dots an duplicate scalar operations where arrays would simplify the code N times.
Where is your top-level loop? What is your architecture? In a state machine, a wait is just one of the states, right?
You have 11 terminals, but only two labels (x or y) shared by all. Very confusing! Why is the orange wire under the case structure?
Message 2 of 12
(4,282 Views)
Throwing out a wild guess...
"Threshold 1-D array" and "Interpolate 1-D Array" with the output of the "interpolate..." wired to "Round toward - infinity" may be useful...
Ben
Message 3 of 12
(4,266 Views)
Interpolate 1-D Array is not actually needed.
Though, if the ranges are evenly spaced, Quotient & Remainder would be a lot cleaner.
Message 4 of 12
(4,240 Views)
You'll need to define your conditions a bit more.  Is this simply take a measurement, wait 10 seconds, take another measurement and compare to previous?  Only wait if there was a level change?  This would be pretty straight forward, but not particularly useful if your data can change relatively quickly. What happens if the level changes during the wait?  Does this reset the counter?
Message 5 of 12
(4,231 Views)
Except he also wants to light a consecutive subset of LEDs. A simpler solution would create code that does both at once. 😉
Message 6 of 12
(4,225 Views)
I saw those LEDs as a quick test of his logic that will be tossed after debugging.
Ben
Message 7 of 12
(4,219 Views)
Never mind. These are of course equal comparisons. I thought they were > comparison acting similar to a VU meter. Now I need to get some coffee. 😄
Message 8 of 12
(4,216 Views)
Make the VU meter an integer?
Ben
Message 9 of 12
(4,203 Views)
Hi.
Thank you for your help. My program procedure has changed, so it is not necessary to identify the range of values because I can receive this information directly. Here is my old VI.
Message 10 of 12
(4,136 Views)
