‎07-29-2013 01:32 AM
Hello.
I want to communicate with SCPI using Labview but I have no idea on how do it. Once I have connected my device to the pc using the ethernet connection how can I send the SCPI commands to the instrument? I tought, but I don't know if I am right, to use the VI patterns; if this could be true, where can I find some infos about the VISA?
Thank you
‎07-29-2013 02:03 AM
What is the instrument (make/model)?
Have you looked for LabVIEW drivers, you may want to search it here.
‎07-29-2013 02:07 AM
No unfortunately they are not NI instruments. One is an agilent instrument. I want to start to practice with this one.
‎07-29-2013 02:16 AM
Have you checked the link, moderator1983 provided?
Please read carefully:
He was talking about INSTRUMENT drivers, not DEVICE drivers.....
NI has a strict terminology on this:
Device: NI product, most often build into the PC/PXI system, nowadays increasing number of USB and E-Net devices available
Instrument: Any third party boxed instrument, interfaces most often Serial (RS232), USB, GPIB or E-Net.
So instrument driver is exactly what you are looking for. And Agilent provides LV instrument drivers for most devices as also Agilent feels the power of LabVIEW....
Norbert
‎07-29-2013 02:24 AM
Oh well sorry I haven't understood it. Now that is clear I checked and those are the two instruments:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=8017
and
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=19037
now that I have found them...what else?
Thank you guys for your help
‎07-29-2013 02:25 AM
You should be going to start your code... ![]()
‎07-29-2013 02:42 AM
Eheh no really I have other few questions.
In the Rigol link that I posted I read:
"This instrument driver is NOT supported or maintained by National Instruments. This driver is maintained and supported by the instrument manufacturer or a third party."
So as suggested I went on the Rigol site
http://www.rigol.com/support/ivi/more.html
but I haven't found the driver. So how to procede? The instrument is the Rigol DSA1030A. What is the procedure to communicate with an instrument of which I don't have the driver?
On the other side about the LeCroy instrument I'm taking some minutes to read how to instal the Plug and Play... I'm talking about this guide:
http://www.ni.com/devzone/idnet/inetinst.htm
‎07-29-2013 02:50 AM
In your earlier post, you mentioned Agilent...![]()
Rigol hasn't provided LabVIEW drivers for this particular instrument, but IVI drivers are available for C-programming-language interfaces (LabWindows) but you can always convert it to something which is compatible with LabVIEW, check this link.
‎07-29-2013 02:52 AM
Hi inuyashi,
when the link provided in the IDN doesn't work you could go the "official" way:
- Open the website of the manufacturer (www.rigol.com)
- Search for your device DSA1030A and open it's product page.
- Nearly all measurement device manufacturers support their devices with additional software: so you would open the tab "Saftwares" on the DSA1030A website.
- Wow: Rigol presents you an IVI driver to download, install, and use...
‎07-29-2013 02:59 AM
Yea I'm sorry it was supposed to be the Agilent but actually it is used by another guy so those two are the instruments I can use.
Ok Great! I'll check the option you suggest me for the Rigol and I'll let you know.
Ty guys
