How to choose the tile on 'list'
Hello imam JSun
I received homework from my higher officer.. T_T
that is very difficult to me so I need your help..
- down is my problem --
1. How do I choose the text on 'list'
2. How to action the function when I choose the text on list ..
plz help me~_~
add file is a my problem vi.. lol
(3,051 Views)
Pls attachVI in 8.6 so that i can help you.
(3,039 Views)
Good luck 😉
Jim
(3,021 Views)
I think "the dog ate my homework" would be an appropriate excuse here.
Richard
(3,009 Views)
@JSun wrote:
Hello imam JSun
plz help me~_~
Please repost your question in your native language.
As it reads now, it sounds like you are asking someone to do your homework.
Ben
(3,005 Views)
(See Also how to i make a new section on list during play vi.?)
The list box has a property node called Item Names that let's you return an array of strings for the items in list.  You can also write to that node to change the list of names.
If you have a create button, you could read the array, add your new item to the end, then write the array back to the property node.
For the delete button.  Read the array, Use Delete from Array using the value of the list box as the index of the array you want to delete.  Then write back the new array to the property node.
(2,980 Views)
