How to change x-axis values from decreasing to increasing in number in XY Graph
I hope you are doing well.
I am working on developing horizontal resistance/strain test rig and so I want to plot Resistance vs Length graph in XY Graph. But every time my graph is starting from highest to lowest x-axis values like if I set 5mm length to start from, then it goes as from 5 to 0. I have tried to add negative function in sketching and also set to invert x-axis from properties of XY graph, but I am not getting desired output; I want to see my plot should start from 0 to highest one value.
For you information, I am using remaining steps output from StepperToGo.vi (LabView Interfacing with Arduino) block for x-axis. I know its output values are decreasing so causing my plot starting from highest to lowest.
Kindly suggest.
(2,169 Views)
Accepted by Afzal6khan
Hi Afza,
@Afzal6khan wrote:
I want to plot Resistance vs Length graph in XY Graph. … I want to see my plot should start from 0 to highest one value.
So you know your X values start with a larger value and decrease to the end of the measurement. And you wonder why the XY graph starts to plot at larger X values and finishes with smaller X values!?
Why don't you scale your X values, like this:
x_scaled := x_max - x_remaining
Seems rather trivial…
(2,165 Views)
@Afzal6khan wrote:
I am working on developing horizontal resistance/strain test rig and so I want to plot Resistance vs Length graph in XY Graph. But every time my graph is starting from highest to lowest x-axis values like if I set 5mm length to start from, then it goes as from 5 to 0. I have tried to add negative function in sketching and also set to invert x-axis from properties of XY graph, but I am not getting desired output; I want to see my plot should start from 0 to highest one value..
Sorry, I don't quite understand your questions. Maybe you could add a picture showing what you gets vs what you want.
If you want the x-axis inverted (i.e. highest value on the left) just set it in the properties:
(2,129 Views)
Am I correct that you are plotting an XY Graph, whose inputs consist of an Array of Clusters of 2 elements, X and Y?  And the Graph plots from highest value of X to lowest?  Have you looked at the Array?  Is the first value the highest, and the last value the lowest?
If so, what operation (on the data, the Array of Clusters) do you think you need to perform to get the first value the lowest?  Do you know how to program this operation?  Where would you look (in the Block Diagram Palette) for such an operation?
(2,119 Views)
Oh man! Thank you. I just needed to focus on that basic logical maths. I have sorted out.
(2,110 Views)
