How to change the plot label
Easy question. I have a 2x2 array going waveform graph. How do I change the labels on each of those plot to the text I want? I look in the property nodes, but couldn't find it. Thanks!
(3,395 Views)
If I understand your question correctly, you want to change the name of the plot.
You can either double click the plot name on the front panel or use the Plot.Name property node to get or change the name of the plot.
Ron Deavers, CLD
(3,387 Views)
Accepted by topic author d1sturbanc3
Hi d1sturban...,
do you mean like this?
Mike
(3,384 Views)
ahh thanks.. I found that property but didn't know I had to set an active plot.
(3,379 Views)
