How to change slider control digital display precision from program
I want to change slider control digital display precision from my Labview 2013 program. I can not find property that changes slider digital display format.
(3,709 Views)
Accepted by topic author Alex_Muz
rt clk the digital display>create>property node>format string
you could also do the slide scale, if needed...
from the front panel:rt clk properties>goto display format tab>goto drop down list and pick "digital display 0" and format
(3,694 Views)
It works!!!
Thank you
(3,660 Views)
thank you so much, this worked
(3,511 Views)
