How to change front panel indicator properties such as background color or enable/disable programmatically?
It's a feeback node and is on the structures palette. It's the same thing as a shift register in older versions of LabVIEW. Both are explained in the on-line help and User Manual. A shift register/feedback node is an important LabVIEW feature and are used to pass values from one iteration of a loop to another.
Message 11 of 11
(723 Views)
