User defined path, assigned file name
I would like enable the user to define the directory where the file created will be saved but keep the naming convention I implemented the same.  I set up a small, and yes crude, program to test out the functionality of the code and its just not working out.  Any suggestions?  I'm, using Lab View 6.1.
LabVIEW 2016 - Windows 7
CLAD
(2,991 Views)
Try replacing the File Dialog function with a Build Pth function.
It looks like you want to append two parts of path together to build a complete path. The File dialog does not do this, it just lets the user select a path. You can then use that path to build the complete path with your filename using the Build Path function.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,986 Views)
That did the trick...Thanks!!
CLAD
(2,977 Views)
