How to capture the click event from the ring control when user select a item?
I would like to create a user interface component like a combo box to let user to select a item in the list. The problem is that I can not track the event after user select a item. What I can do is to build the another button for user to click it for notify the program that he need to select item. Please advise me.
Rattgarn V.
(2,831 Views)
You can use this ring control into a loop, and make your program act everytime it changes, taking one or another decision depending on the value returned by the control.
Hope this gives you some ideas
(2,831 Views)
You might take a look on Ring With Latch Action.VI in lv folder\examples\general\controls\ring.llb ... maybe it maches your application requirements.
Good Luck!
(2,831 Views)
