How to build safety login system?
I'm building a simple user login system. like following
01. Build a database(SQLite)
02. Insert the login information( Username and password)
03. Login Interface, the vi will search the match User.
But i think it is too risky, because anyone can access the database via kind of tools.
Can you share the experience to us about the safety login system?
(4,302 Views)
One option is to rely on Windows (assuming that is your OS...).
Look at this API call:  https://msdn.microsoft.com/en-us/library/bb300969(v=vs.110).aspx
You can validate either a local or domain account.
(4,293 Views)
Accepted by LabviewKK
You could encrypt the user/password database.
Basic encryption is simple XOR a data stream and a repeating key, decrypt by XOR the encrypted data with the same key.
The longer the key the more secure the encryption.
Now you can store the user/passwords in a plain text file.
Read and decrypt the file into an array and do your user checking that way, no need for SQLight
=== Engineer Ambiguously ===
(4,277 Views)
Hi
If it is, i have a root count( user: root and password: root), someone can decrypt the key?
(4,269 Views)
@LabviewKK wrote:
Hi
Yes the encryption key is defined by you and would be "hard coded" into your executable so you don't have to enter it every time.  Also that means the key is not stored in clear text anywhere on the computer so even root can not just "find" the key
But sure someone who really knew what they were doing could probably look at the compiled code and find the key. But why would they?
Having never worked with SQLight I can only guess but I think it would work if you encrypted everything as you wrote it and decrypted as you read it.
(4,267 Views)
I've saved the MD5 hash of a password + salt in a database.  That felt secure to me.
Jim
(4,231 Views)
Can you share the Vi for reference?
Because i can not drag the picture to Labview directly.  I don't know why.
(4,214 Views)
