取消
显示结果
搜索替代
您的意思是:
How to bind my variable to an OPC item?
I have connected my Siemens S7-1200 PLC to Labview OPC Server 2012 successfully. I can monitor the variable using Quick Client.
Now I want to have this variable in my vi. I made a new VI and using the Data Binding, But when I try to bind this variable to my OPC item I get the following Error:
Does anybody know what is the problem?
Regards
0 项奖励
1 条消息(共 8 条)
6,196 次查看
A Labview DSC module is required, with which the OPC server is supplied. The message indicates a malfunction: the lack of a license.
Labview 4.0, 5.0, 6.1, 8.6, 2009, 2011, 2012, 2014
If you do not know something, ask me.
2 条消息(共 8 条)
6,173 次查看
Thanks Borjom. So I need DSC Module to bind my variables to OPC items! Before than this I had used OPC with Easy OPC a product of Moeller which could simply be used by Data Binding. Seems things have changed!
So would you please give me a start point to learn about DSC and how I can use OPC Items using this module?
Regards
0 项奖励
3 条消息(共 8 条)
6,149 次查看
You do not have to do anything. The problem is only in the license. First, check if the license for NI OPC is active.
0 项奖励
4 条消息(共 8 条)
6,142 次查看
 But I have installed OPC Server 2012 without installing DSC Module.
0 项奖励
5 条消息(共 8 条)
6,130 次查看
beginner,
I believe you still need to get a certificate for/activate the OPC server you're trying to connect to.
6 条消息(共 8 条)
6,099 次查看
Hi All,
I can bind my variable to an OPC, and no error. But now the problem is when I using OPC Quick client to monitor the tag I set, the data I get same with what I set into the PLC (Mitsubishi FX3G), when I using LabVIEW VI to monitor the same tag, the data I get is 0. Can anyone help? Thanks
I am not using DSC runtime system and is it necessary to have it?
Best Regards,
Sam
0 项奖励
7 条消息(共 8 条)
6,026 次查看
Re-installed, problem solved.
0 项奖励
8 条消息(共 8 条)
6,016 次查看
