How to bind my variable to an OPC item?
I have connected my Siemens S7-1200 PLC to Labview OPC Server 2012 successfully. I can monitor the variable using Quick Client.
Now I want to have this variable in my vi. I made a new VI and using the Data Binding, But when I try to bind this variable to my OPC item I get the following Error:
Does anybody know what is the problem?
Message 1 of 8
(6,177 Views)
A Labview DSC module is required, with which the OPC server is supplied. The message indicates a malfunction: the lack of a license.
Labview 4.0, 5.0, 6.1, 8.6, 2009, 2011, 2012, 2014
If you do not know something, ask me.
Message 2 of 8
(6,154 Views)
Thanks Borjom. So I need DSC Module to bind my variables to OPC items! Before than this I had used OPC with Easy OPC a product of Moeller which could simply be used by Data Binding. Seems things have changed!
So would you please give me a start point to learn about DSC and how I can use OPC Items using this module?
Message 3 of 8
(6,130 Views)
You do not have to do anything. The problem is only in the license. First, check if the license for NI OPC is active.
Message 4 of 8
(6,123 Views)
 But I have installed OPC Server 2012 without installing DSC Module.
Message 5 of 8
(6,111 Views)
beginner,
I believe you still need to get a certificate for/activate the OPC server you're trying to connect to.
Message 6 of 8
(6,080 Views)
Hi All,
I can bind my variable to an OPC, and no error. But now the problem is when I using OPC Quick client to monitor the tag I set, the data I get same with what I set into the PLC (Mitsubishi FX3G), when I using LabVIEW VI to monitor the same tag, the data I get is 0. Can anyone help? Thanks
I am not using DSC runtime system and is it necessary to have it?
Best Regards,
Sam
Message 7 of 8
(6,007 Views)
Re-installed, problem solved.
Message 8 of 8
(5,997 Views)
