How to automatically load a configuration .ini file on VI startup?
Hey everyone,
I have the following VI in one of the projects I am trying to work on. It is loading a configuration parameters for a camera. This VI comes as preconfigured from the manufacturer, but it uses this File Dialogue Express VI, which will prompt always to select the .ini file neede.
I want to remove it and load the file automatically on VI startup. So far so good, but how do I load the file in case when this VI will be built as an application and the application installed on a different PC? I am not familiar with Application builder, but how to include this configuration .ini into the installation folder, so that it can be loaded always properly when used on different computers?
P.S. The actual .ini manipulation is in the sub-VI load from ini.
(2,929 Views)
Accepted by topic author grumpy_numpy
Hi grumpy,
I see two simple options:
  1. add that "camera" ini file as an additional file to your AppBuilder configuration. Now you can define the location of that additional file, default is a "data" subfolder next to your executable…
  2. add the content of that "camera" INI into the ini file of your executable, so your executable only needs to read it own ini located in the same folder right next to the executable…
(2,925 Views)
Hey Gerd,
I love your solutions! Always so simple. Thanks a lot!
I will build it quickly and test asap.
bests
Georg
(2,921 Views)
Hey Gerd,
getting the following error:
I used the Current VI path VI.
(2,896 Views)
Hi grumpy,
Why do you do that? (And why don't you use BuildPath to build a path???)
Did you verify the path which is created this way? It seems (very) unreasonable as it is shown in that error message…
Using CurrentVIPath is wrong: use the ApplicationDir file constant to get the path of the executable!
(2,885 Views)
