11-25-2020 05:43 PM
I have a complex cluster, containing numerics, strings, bools, arrays and even another clusters.
If I change element values in frontpanel, I need an event case that gives me the reference or information of the changed element to show name and new value. (Kind of event logger)
I tried to compare with "unequal" old and new value in event case. This gives me an array of bools. I can compare that with my elements[]. That works.
But what if I have a cluster in cluster? Any ideas?
11-25-2020 10:21 PM
That's not quite right. When I set up a cluster within a cluster, the result of the comparison is a cluster in a cluster structure where the various elements compared (numerics, strings, ....) are show up as booleans. It is the same hierarchy as the original cluster, not an array of booleans.
11-26-2020 01:15 AM
Thanks for your answer.
I know, thats my point. If I had only a simple cluster, I could convert the result of the comparison to an array of bools and walk through the elements.
But how can I do that, if I have cluster in a cluster?
12-03-2020 09:43 AM
You could try iterating through the cluster to find booleans. If you find a nested cluster then call the VI recursively. The array implementation needs work though.
Search the VIPM for OpenG toolkit to get the SubVIs.
