How to apply bilateral filter over a 2d matrix image
@gptshubham595 wrote:
Hey Rahul you can use this directly to do this using above python code and python integration toolbox via Enthought
 if you don't put
hl = int(diameter/2)
you'll get
gi = gaussian(source[neighbour_x, neighbour_y] - source[x,y], sigma=sigma_i)
IndexError: only integers, slices (`:`), ellipsis (`...`), numpy.newaxis (`None`) and integer or boolean arrays are valid indices
and you should add
 gi = gaussian(x=float(source[neighbour_x, neighbour_y]) - source[x,y], sigma=sigma_i)
or there will be
RuntimeWarning: overflow encountered in ubyte_scalars
Message 11 of 26
(2,318 Views)
.. using above python code and python integration toolbox via Enthought
rather use the python node
Message 12 of 26
(2,307 Views)
thank you!
ISSUE: ERR IN READING INPUT IMG
I tried your code it is giving me an output image but in order to read input image it is giving error
but can you help regarding this error?
Message 13 of 26
(2,289 Views)
Sorry it was error due to png file read as jpg file
replacing read jpg file.vi to read png file.vi  worked
ThankYou
Message 14 of 26
(2,288 Views)
I wanted to see, if I can reduce JPG artefacts by bilateral filtering
Actually, we don't need the opencv-python package to read jg or png.
attached is  a more polished version, in LabView 2020 x64
Message 15 of 26
(2,270 Views)
Is the image b&w (8bit greyscale) or RGB (24bit)?
I think all you need to do is a 2D convolution with a 2D Gaussian. Code should fit a postage stamp. No Python.
Message 16 of 26
(2,260 Views)
Here's how that could look like (note that the edges need to be corrected for the truncated kernel, shown is one possible simple correction). Note that the blur scale is arbitrary and might not correspond to other libraries.
Message 17 of 26
(2,253 Views)
the main intention is not to get a blurred image, instead, we wanted to apply a bilateral filter over the image, in order to get a clean curve and reduce noise
like
initially we have (good freq)>=(noise)
frequency*1000 then we have (good freq)_new >> (noise) _new
GKalliatakis/Bilateral-Filtering: Applying Bilateral Filtering to images (github.com)
Message 18 of 26
(2,247 Views)
Sure. I am just saying that all that could be implemented in G directly. Probably not that hard.
Do you have an example image before and after the desired filtering?
Message 19 of 26
(2,236 Views)
Message 20 of 26
(2,232 Views)
