How to append string data to a table?
I am trying to append data to my table but is just overwriting the previous result. Have tried to use a shift register but still overwrites. I have attached my code for a perusal.
Message Edited by Molly K on 02-10-2005 09:25 AM
(4,177 Views)
The vi is called SCOPE TEST
(4,172 Views)
Read the data (Unbundle), pass it to Insert Into Array, and connect the output to the Bundle node.
If you leave the indexing terminals of Insert Into Array disconnected it will append.
Lynn
(4,165 Views)
Try this (LabVIEW 7.1):
(You still need to polish it up a bit, eg. add means to clear the table, or prevent it from growing indefinitely)
(4,159 Views)
Thanks for the help but the initialise vi creates an error code now. Any ideas??
(4,123 Views)
Hi Grant,
What's the error code????
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(4,096 Views)
Re-booted and restarted labVIEW and problem cleared. MMmmmm? Works OK no anyway thanks.
(4,092 Views)
