How to append 1-D Array to report.....
I want to append 1-D array to a report but when i use the append table to report's VI then it wants 2-D array to connect to it. But if i want to append 1-D Array to a standard report then i don't know how to do this.
Please help me in this regard...
(3,326 Views)
can u post a pic of your vi ...
(3,306 Views)
Accepted by topic author Waqar123
You could try this.
Hope this helps.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,300 Views)
if you want 2d to 1d ...  the simple idea should be to use a replace array subset function and input the 2 D array and index only the row or coloumn..
1d to 2d --- can be done by build array funtion adn then use transpose function ..so that you have 2d arrays with 1 array of usefull info and the other array as dummy values...
(3,289 Views)
Thanks a lot to all of the friends who replied to my post. I actually got the idea from your replies and finally got it work according to my requirement.
Thanks again.
Regards
WAQAR
(3,271 Views)
