How to append 1-D Array to report.....
I want to append 1-D array to a report but when i use the append table to report's VI then it wants 2-D array to connect to it. But if i want to append 1-D Array to a standard report then i don't know how to do this.
Please help me in this regard...
(3,338 Views)
can u post a pic of your vi ...
(3,318 Views)
Accepted by Waqar123
You could try this.
Hope this helps.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,312 Views)
if you want 2d to 1d ...  the simple idea should be to use a replace array subset function and input the 2 D array and index only the row or coloumn..
1d to 2d --- can be done by build array funtion adn then use transpose function ..so that you have 2d arrays with 1 array of usefull info and the other array as dummy values...
(3,301 Views)
Thanks a lot to all of the friends who replied to my post. I actually got the idea from your replies and finally got it work according to my requirement.
Thanks again.
WAQAR
(3,283 Views)
